question one place i work is a 5 hour show and i have some problems in the last hour sometime a music video will lock up for a second then i just have to reactivate or it will lock up it only happens in that last hour just wondering any settings adjustment i can make to correct..all my drivers are up to date and i use all the video settings in VDJ any feedback welcome. was wondering if turning of the hardware acceleration would help since only music videos are being done?
I found a interesting read not sure of the result?
https://virtualdj.com/forums/86751/General_Discussion/Unmark_Hardware_acceleration_but_still_Effects____.html
geposted Sun 10 Jul 11 @ 4:27 pm
not sure what the problem is but i use my numark cue and the video is stable all 5 hrs with no hick ups at all with the hardware acceleration where can i find the patches that where updated from 7.2 to 7.4 i might just want to roll it back
geposted Mon 11 Jul 11 @ 10:49 pm
hmm not sure now i got the dj4set and looks like the update was for it, anyone having video issues when they use the dj4set?
geposted Mon 11 Jul 11 @ 11:23 pm
you can close this out believe it or not the vibration from the speakers where the cause of the skipping cause a bad vibration on the pc so i corrected the issue.
geposted Sat 16 Jul 11 @ 11:51 am
