Hi all,
I've got the newest macbook pro and i have a hercules rmx with limited vdj. I want to be able to use my mic but i dont want the sound of the music to drop, i want to be able to drop the track using the faders manually.
There is an option on the hercules control panel but it wont let me move the setting?
Any help appreciated
Ryan
Ryan
geposted Mon 11 Jul 11 @ 2:24 pm
You should be able to disable the Talk Over Attenuation from the DJ Control Panel (click the Green X).
If you can't interact with the DJ Control panel, be sure that the Rmx is connected to the computer.
To be sure the Rmx is installed properly, consult this document:
http://ts.hercules.com/faqs/eng/her_eng_00351.pdf
geposted Tue 12 Jul 11 @ 7:00 am
