What is the difference in the "normal" beatgrid interface and the beatgrid interface in "micro-grid" mode (accessed by the small icon on the bottom left of the beatgrid beat layout).......the micro grid that looks all zoomed in......Thanks guys.... =D
geposted Mon 11 Jul 11 @ 6:44 pm
In musical terms, in normal view you see the 4 beats of a bar (phrase), while the same bar is divided in 16 sections (1/16) in the micro grid.
So in the micro grid you can create more complex patterns, if this is what you need.
geposted Mon 11 Jul 11 @ 6:58 pm
Makes good sense......So when I'm seeing the "Micro Grid View" there are just more detailed beat adjustments I can make (4beats beats per, and on the "Regular Grid View" there are more broad adjustments the 4 beats are now 1 block correct?)...Thanks for the help!
.....and are you determining what patterns to use simply by what is sounding good to you?...........
geposted Mon 11 Jul 11 @ 7:21 pm
Take a look at some Beatgrid patterns you may create using micro grid or normal.
http://it.virtualdj.com/forums/149138/VirtualDJ_Plugins/THESE_ARE_MY_FAVORITE_BEATGRID_PATTERNS____WHAT_ARE_YOURS_.html
geposted Mon 11 Jul 11 @ 9:55 pm
