Okay so I have Vdj Le on my macbook pro and I just bought a Numark Mixtrack.
How do I set it up so that I can here the song thats not the program? I think its called the cue...
Do I need to buy another piece of equipment to plug them in? I tried to plug it in the headphone jack and I got nothing....I'm very confused about all of this!
geposted Tue 12 Jul 11 @ 2:53 pm
It would be for interest what kind of soundcard you are using and how your VDJ soundcard setup looks like.
geposted Wed 13 Jul 11 @ 6:14 am
The original soundcard that mac-pros come with!
geposted Wed 13 Jul 11 @ 3:58 pm
When i'm right the build in soundcard has only a MIC/Linein and a Headphone port.
So only one stereo output!
You have to split the Headphone Output signal with a Y-cable.
One to the speakers and one to headphone.
On VDJ side you have to select:
Input None
Output - Headphone
Soundcard Mono-separated.
But then you have a Mono signal on your headphone and the speakers.
But the better way is to buy a DJ soundcard like the Audio2DJ or something simular to your needs.
Input None
Output - Headphone
geposted Thu 14 Jul 11 @ 8:31 am
Thanks so much! I've been struggling trying to figure this out for a while now!
geposted Thu 14 Jul 11 @ 6:09 pm
