Look Out Callaway diablo edge irons
The finish to the flop shot will resemble the look of your full swing with callaway diablo edge irons. You will have rotated your torso to the point that you will have pulled up onto the toe of your back foot. As your wedge.s shaft is parallel to the turf past impact, your right forearm should not cross over your left forearm to keep the clubface from store of diablo edge irons for sale. Hold this position until the golf ball has hit the putting green.So the next time you are not able to run the ball up onto the green, with a little practice, this golf shot will help you lower your score. In addition, if on fast greens, the flop shot can help you get the ball close to the hole. Go the practice area at you country club or golf course and use this information to learn to hit the lob shot and watch your scores come down.
geposted Thu 14 Jul 11 @ 10:39 pm
I need one of these...
geposted Fri 15 Jul 11 @ 8:45 am
Why the hell is this in the freaking Mix section? Actually why is it even on this forum?
geposted Fri 15 Jul 11 @ 10:20 am
