Hi everyone. Is there an easy way to increase the font size of the track listings using the standard VDJ7 skin? It is really small and hard to read when I'm playing in the club. I know that Serato has a option to increase the font size in the settings menu but I don't see something similar in the VDJ menus. Any help or suggestions anyone has would be appreciated.
geposted Thu 14 Jul 11 @ 11:42 pm
Some newer skins have that feature but not the default one at this time. Editing the skin XML browser section to increase the font size is the only solution.
Keith
Keith
geposted Fri 15 Jul 11 @ 12:50 am
quality is a bit naff but i made it for youtube specs three years ago... this will show you how to change font and add a logo if you want to your browser.
hope it helped.
geposted Fri 15 Jul 11 @ 3:05 am
When I click on skins it opens up with the size screens like 1024x600 Paint shop pro
1024x600 xml document
1024x768 Paint Shop Pro
1024x768 xml document
and etc.
Is that on an older version of VDJ cause also when I opened up skins I noticed I have 4 deck skin, 6 deck skin VDJ 5 Skin and 2 Deck skin and I opened the 2 Deck skin.Tayla I got on gigatribe to see if you were on there but you werent
and etc.
geposted Fri 15 Jul 11 @ 3:23 pm
Hi mate, best to contact me on skype at Firetext.VDJ.Support (would have been at gig when you contacted me on gigga).
geposted Sat 16 Jul 11 @ 6:21 am
