Heya All,
I love Virtual DJ, and swear by it. I have recently started using Timecoded CDs (VDJ Timecode) and after a while I noticed that my CDJs had a command cap, For example you press the cue button really fast and It would only stick to a certain speed. I just thought, Well the CDJs were cheap enough and I didn't expect the performance of the Pioneer range..
That was until I used another branded timecode solution software, and found out that it was not my CDJs after all, But the response/command time of the VDJ timecode, On the other branded software/timecode It keeps up pefectly - Allowing me to go crazy on the cue button and manages to keep up!
I was wondering If there maybe an option or something to tweak to allow the response time of the Virtual DJ timecode to be improved?
Regards
Regards
geposted Fri 15 Jul 11 @ 11:28 am
