i have a brand new 2011 macbook Pro and a denon 4500. under sound settings i cannot change the 2nd deck to the 2nd sound card in the controller.. it won't give me the option. I've been using it on my HP win 7 laptop and it works perfectly on it. any ideas.? i tried installing the software from the denon cd and it doesn't know what to open the asio drivers with
geposted Fri 15 Jul 11 @ 9:01 pm
Hi,
you have to do some settings on Mac side ;-)
https://virtualdj.com/wiki/Denon%20HC%204500%20auf%20Mac.html
It is in german, but the pics should guide you ;-)
If you have trouble to understand, come back.
geposted Sat 16 Jul 11 @ 5:09 am
Thanks, i found the same solution (in English) on the denon site. thanks for the help
geposted Sat 16 Jul 11 @ 5:52 pm
for anyone having similar issues... here's the link for the solution...
http://www.denondj.com/DN-HC4500-P81.aspx# then click on the MAC Audio/MIDI Configuration Manual (English) tab
geposted Tue 19 Jul 11 @ 12:05 pm
