Hello all
Right now I have a SL1 that I use with vdj but I would like to buy a SL3 or maybe s SL2. The
thing is I also play audio cds doing mt sets. I know in Serato you can change from timecode
to audio cds. If i'm playing with vdj is there away to do this..? If not will there be away to do
this soon I see a lot of new sound cards work like this now.
thanks
thanks
geposted Sat 16 Jul 11 @ 3:52 pm
yes sum skins have a (time code) off & on switch. if a certain skin dont have it then u kan just map one of your keyboard key to be the on & off switch i did it like that b4 i got my sl3 which has the on/off feature on its skin also
geposted Sat 16 Jul 11 @ 8:04 pm
thanks man on the mapper tap what is it called... thanks again
geposted Sat 16 Jul 11 @ 8:49 pm
The script would be "deck 1 timecode_bypass" and the other is "deck 2 timecode_bypass"
Good Day
Huey
Good Day
Huey
geposted Sat 16 Jul 11 @ 11:15 pm
