I'm off on holiday on Friday and want to mix a couple of songs together. I can easily do this using the free version of VDJ but i want to be able to improve the mix by previewing the songs using headphones but i have no idea how to do this without using some kind of external usb(since i have a laptop). Does anyone have any advice on the software needed for me to be able to do this? Thanks
geposted Sun 17 Jul 11 @ 9:31 am
In order to be able to prelisten the songs using headphones, you have 2 options with Home Free version..
1. Plug a Y-Splitter cable/adaptor to you laptop's headphones input and connect a pair of speakers to one side and headphones to the other.
2. Plug a simple stereo USB sound card to your laptop and connect headphones there.
Choose the appropriate picture from the Config->Sound setup
geposted Sun 17 Jul 11 @ 6:16 pm
Thank you!
geposted Tue 19 Jul 11 @ 4:16 pm
#2 is the best option or you only get mono output for both speakers and headphones.
geposted Tue 19 Jul 11 @ 4:18 pm
