Help me please. I am trying to stream using Virtual DJ Pro but it keeps losing the settings. Also, I am not able to use mic. Anyone have the same issue or can anyone offer help?
geposted Sun 17 Jul 11 @ 10:50 am
Need help configuring mic when using Hercules MK4. What can I do? I had the mic configured but the mixer wouldn't work and I lost the settings to stream.
geposted Sun 17 Jul 11 @ 10:53 am
ok calm down lol same question twice in 3 mins.
when you say your trying to stream, do you mean your trying to broadcast?
also, when you use vdj with an external controler and mic, the mike input in the unit isnt a feed into the computer. its purely a throughput. meaning the mic signals will be reproduced only to your main output.
if you want to use a mic with vdj, then you need to plug it into your computer.
can yu please tell us ecactly what it is you want to achieve. and also how you had things connected and setup?
thanks.
thanks.
geposted Sun 17 Jul 11 @ 11:25 am
