I just recently bought a used sytem. Denon Hc4500 and x500 mixer and need help setting it all up with VDJ. I have VDJ pro for mac.
geposted Sun 17 Jul 11 @ 9:23 pm
What problems are you having? i have the exact same setup.
go to http://www.denondj.com/DN-HC4500-P81.aspx# and click on the MAC/audio midi configuration manual. that'll get the 4500 setup for 4 channel 1/2-3/4 output.
geposted Tue 19 Jul 11 @ 11:47 am
also, this is from another thread and might be helpful....
Date: Tue 07 Dec 10 @ 8:27 pm
Teamer: jpboggis
Message: Please check the permissions on your VirtualDJ folder are set correctly:
* Go to the /users/YOURNAME/Documents folder and Control+Click (Right click) on the VirtualDJ folder.
* Choose Get Info from the pop-up menu.
* In the bottom right corner of the Get Info dialog, click on the pad-lock icon and unlock it (You will be prompted for your user password.)
* Then just above that to the left is the Permissions list. Make sure that your user account has Read/Write permissions set.
* Just below the Permissions box there is a button with a gear graphic on it - Click on it and choose the 'Apply to all included' items.
* Once changed, close the Get Info dialogue box to apply the changes.
NOTE: If you use external drives, you will also need to do the above for each external drive.
NOTE: If your external drive is PC NTFS formatted, then VIrtualDJ will not be able to write to it and save your database information. The drive must either be natively formatted for Mac use only, or if you wish to also use it on a PC, it must be formatted FAT32. Mac can't write to PC NTFS formatted drives
Teamer: jpboggis
geposted Tue 19 Jul 11 @ 11:59 am
geposted Tue 19 Jul 11 @ 12:53 pm
i need help choosing the right channels for the denon x500....I'm a begginer and I'm having a difficult time to set up my denon x500 mixer the proper way along with the denon 4500 and virtual dj...Im really confuse of which channels to use to make the fader work and the headphones
geposted Thu 25 Aug 11 @ 2:28 am
