just needed some advice,
Me and a friend just purchased some NDX800s, Numark DJIO soundcard and he is using VDJpro.
We conntected it all up fine yesterday and the results were amazing. all functions seemed to work.
Just needed some help on a few functions, ( Possibly NDX user can help? )
1) on vdj you have an auto sync button on the screen, is there a way to use that auto sync feature on the ndx control if so how?
2) Also we are fine looping on the screen, but there is a loop in , ou , and reloop function on the NDX we cannot seem to get this working right, i.e. loopin in then we cannot get it to stop loopin and playing normal. What is the correct way of using this feature on the NDX.
thanks for your help people greatly appreciated :)
geposted Mon 18 Jul 11 @ 5:20 am
If you are using VDJ pro/full then you can just mapp all your button or some off your cd's W/usb.
geposted Mon 18 Jul 11 @ 6:31 pm
