hey,
I am currently using virtual dj on a pc, which has all my bpm's and cues saved up. i'm planning on buying a mac soon and it will be a shame if hours and days of work will go to waste. how do I make sure that all the song info's from my pc will import to the mac?
thanks a lot
thanks a lot
geposted Mon 18 Jul 11 @ 9:20 am
Hey,
use the search function and you will find here all answers!
geposted Tue 19 Jul 11 @ 2:02 am
I had the same issue before and raised a ticket. Here's what I got from the support team.
(You might want to have a new external drive first then do the steps belos)
Goodluck!
Date: Tue 07 Dec 10 @ 8:27 pm
Teamer: jpboggis
Message: Please check the permissions on your VirtualDJ folder are set correctly:
* Go to the /users/YOURNAME/Documents folder and Control+Click (Right click) on the VirtualDJ folder.
* Choose Get Info from the pop-up menu.
* In the bottom right corner of the Get Info dialog, click on the pad-lock icon and unlock it (You will be prompted for your user password.)
* Then just above that to the left is the Permissions list. Make sure that your user account has Read/Write permissions set.
* Just below the Permissions box there is a button with a gear graphic on it - Click on it and choose the 'Apply to all included' items.
* Once changed, close the Get Info dialogue box to apply the changes.
NOTE: If you use external drives, you will also need to do the above for each external drive.
NOTE: If your external drive is PC NTFS formatted, then VIrtualDJ will not be able to write to it and save your database information. The drive must either be natively formatted for Mac use only, or if you wish to also use it on a PC, it must be formatted FAT32. Mac can't write to PC NTFS formatted drives.
Goodluck!
Teamer: jpboggis
geposted Tue 19 Jul 11 @ 9:15 am
