Just bought the software but am having trouble setting up an external sound card. The one I have is here:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=270673601253
I have configured it on the laptop and managed to get an output eventually. I plugged on the Hercules mixer and tried to hook up a set of speakers and eventually got them working by plugging them into the 'line out' jack on the external sound card. I tried pluggging in the headphones into various other of the remaining 3 jacks but no luck even though I kept changing the config settings in the software. Then I looked at the mixer and the two headphone monitoring buttons. If there was a track playing on deck 1 and the headphone button 1 was down then the sound comes out of the speakers but if I put the headphone monitor on 2 then nothing. Seems to me that the way I have it set up the speakers are acting like headphones! Help anyone??
geposted Tue 19 Jul 11 @ 1:51 pm
The following procedure does not apply to this specific soundcard, but the principle is the same and it should give you are head start about how to proceed:
http://ts.hercules.com/faqs/eng/her_eng_00401.pdf
geposted Tue 19 Jul 11 @ 2:54 pm
hiya mate, what herc are you using?
also have a look at this...
https://virtualdj.com/homepage/Blulite/blogs/4511/Headphone_Setup_and_Usage_Guide.html
theres a huge amount of info in there that will be relevent to your situation. any questions, just ask and ill answer as best i can.
geposted Tue 19 Jul 11 @ 3:28 pm
