Forum: Old versions
Topic: xml mappers?
Hello,
Today I spent about an hour configuring my mappers with some midi controller ive had for a while. Unfortunately nothing saved. I read on here that you could type an xml document to save your mappers. I have experiance with xml, but have no idea how you would program something like that. Please give some advice!
Thank you for reading!
-Mike
geposted Sat 23 Jul 11 @ 2:45 am
You can write the xml file in a basic word editor like wordpad or notepad, then just save it as "whatever.xml" so vdj can read it. Check out the wiki for further details, but if you register your serial there is heaps of controllers already pre mapped most with definition files, yours may be there...
https://virtualdj.com/wiki/Controller_Definition.html
