I am befuddled by two occurances during a gig last night; firstly, using my back up PC for the first time (Viao w/ Win 7), I plugged in my Creative X-fi 5.1 sound card and set it as I usually do in VDJ Full Pro. The audio would only playback through deck 1. Music on deck 2 would also play through deck 1 volume control on my mixer. I have used this card and config forever and indeed even the night before but on a MacBook using XP. Is there something about Win 7 & VDJ Full Pro that could be causing this hiccup?; secondly, the aforementioned Sony has an Intel core i3 2310M CPU @ 2.10 Ghz with 4g of ram. All of my videos were choppy. It looked like I had a strobe effect in place. I bought this particular PC as a back up because, at a reasonable price point, the numbers indicate that it should easily handle video. I'm so confused... one last spec: the system is 64 bit.
Any insights and/or cures are very much appreciated.
Thanks,
Jay
Thanks,
Jay
geposted Sun 24 Jul 11 @ 2:51 pm
Hi mate
My first port of call would be to check that you do not have the card configured to Single Output in VDJs Sound Setup menu.
Daz
Daz
geposted Sun 24 Jul 11 @ 10:03 pm
