Is it possible to use Traktor Audio 10 controller with Virtual DJ.And if so,how go about the set up.Thanks for the help.
geposted Sun 24 Jul 11 @ 3:41 pm
yes, plug your turntables in as normal to the soundcard
left deck > input 1/2
right deck > input 3/4
out 1/2 to mixer channel 1
out 3/4 to mixer channel 2
goto vdj config > sound setup and set it to
inputs = timecodes
outputs = single
soundcard = asio or if it shows the audio 10.
inputs = timecodes
outputs = single
geposted Sun 24 Jul 11 @ 3:58 pm
I get my NATIVE INSTRUMENT AUDIO 10 controller to work with VIRTUAL DJ.
The next question is,can i use my herclues rmx controller just as a regular mixer
and audio 10 as sound card.To me the audio 10 has a better sound card.Thanks
for the help.
for the help.
geposted Wed 27 Jul 11 @ 3:26 pm
The Rmx is actually a midi mixer not a regular (audio) mixer.
But yes, you can use the audio 10 for the sound setup and the Rmx as a midi controller for the virtualdj's internal mixer.
In this case you need to setup your audio10 soundcard for : Master + Headphones. (Master -> Out 1-2, Headphones Out ->3-4)
geposted Wed 27 Jul 11 @ 5:04 pm
