Forum: VirtualDJ Skins
Topic: Modify Cue Default Skin
Hi All,
Can someone please tell me how to modify the default skin for the following;
Basically I will be using a knob to select various cues, which should be displayed on the UI and a Denon 5500 controller (see this link for more info:
https://virtualdj.com/forums/151314/Hardware_Technical_Support/Cue_Point_Browser_Map.html).
If possible, I would like the default skin HotCue button(s), and Denon 5500 controller, to display the selected cue number when one of the following variables are activated;
(Please show the exact string(s) required to accomplish this task)...
var 'fx_butt' 1 ?
var 'fx_butt' 2 ?
var 'fx_butt' 3 ?
var 'fx_butt' 4 ?
var 'fx_butt' 5 ?
var 'fx_butt' 0 ?
Thanks in advance for your help!
ClayDJ
geposted Tue 26 Jul 11 @ 4:23 pm
Oops, I have a typo in my previous post for the varables. My previous post should have read:
var 'cue_jump' 1 ?
var 'cue_jump' 2 ?
var 'cue_jump' 3 ?
var 'cue_jump' 4 ?
var 'cue_jump' 5 ?
var 'cue_jump' 0 ?
ClayDJ
You need to create panels that have exactly the same values like these ...
<panel id="cuepan1" group="cuepanels" visible="var 'cue_jump' 1 ">
<pos x="44" y="33"/>
<size width="100" height="90"/>
<down x="+0" y="+0"/>
</panel>
<panel id="cuepan2" group="cuepanels" visible="var 'cue_jump' 2 ">
</panel>
etc
all must have the same group name.
Those panels will be visible according to the value of the variable 'cue_jump'
Thanks for your help Dad!
Synthet1 is helping me with some mapping issues, so I may still need a bit of tweaking for this skin.
I'll check back in and let you know how I make out.
Thanks again,
Clay
