Well, I am unable to keep up with things as much as I would like to so I want to know if I can sell my VDJ Pro license and how I could go about it?
Thanks for the great software!
geposted Wed 27 Jul 11 @ 11:32 pm
No, you can't sell it.
geposted Thu 28 Jul 11 @ 12:07 am
You can not resell the license according to the EULA Atomix Production :
https://virtualdj.com/atomixproductions/disclaimer.html
VIRTUAL DJ SOFTWARE EULA
VIRTUALDJ SOFTWARE END USER LICENSE AGREEMENT
EULA SUMMARY:
- This license gives you the right to install and use the software on a maximum of two computers, by one person.
- It does not give you the right to rent or sell computer systems on which the software is installed, or to rent or sell the software or part of it.
- The software is distributed "as-is" and no warranty of any kind is expressed.
- Atomix Productions and its suppliers retain all intellectual property rights in the software.
- Once activated, the software cannot be refunded, unless found to be defective by Atomix Technical Support.
- Software purchased on-line for instant download through our website is considered opened at the time of purchase, and therefore no refund can be given.
----- VirtualDJ End User License Agreement -----
1. PERMITTED USE AND RESTRICTIONS
You are granted one license to:
- install and use the Software on one computer.
- install and use the Software on a second computer, if this computer is normally used by the same person and the Software will not be used on both computers at the same time.
- make back-up copies of the Software for archival purposes.
This license does NOT allow you to:
- rent, lease, sell, lend, distribute, publish, bundle or sublicense the Software or any part of it.
- rent, lease, sell, lend or distribute hardware on which the Software is installed, unless specifically authorised by Atomix Productions.
- electronically transfer the Software from one computer to another or over a network.
- decompile, reverse engineer, disassemble, or otherwise reduce the Software to a human-perceivable form.
- modify the Software or create derivative works based upon the Software.
Sincerely, Yan DJ Rewop
EULA SUMMARY:
geposted Thu 28 Jul 11 @ 2:17 am
