Got the Numark DJ2Go! You can see the icon on my profile on the left side! :-)
geposted Sat 10 Sep 11 @ 1:15 pm
... and it looks like it's already messed up.
See the last post here: https://virtualdj.com/forums/107208/Hardware_Technical_Support/NUMARK_Hardware_Products_(Setup__Solutions__Fixes__Issues__etc_).html
geposted Sat 10 Sep 11 @ 2:21 pm
Not sure whats wrong with but it is a cheap plastic unit. I think of them like my Korg Nano's, there just THROW AWAYS. I dont think there really made to last even if it is for a few days.........
Good Luck
Huey
Good Luck
Huey
geposted Sat 10 Sep 11 @ 4:25 pm
@aalaap.. you should've listened. I went through you're same dilemma. Hercules rmx+VDJ pro=Flawless System:)
geposted Sat 10 Sep 11 @ 11:56 pm
"cough" iDJ "cough" still going strong after a fair bit of abuse from hammering the buttons and knobs, although the faders are a little weak but the platter is bullitproof, it is the only dj controller icon make so they are built well within an extremely tight budget. probably designed to last longer than any cheap numark offering...
geposted Sun 11 Sep 11 @ 12:01 am
Figured out half of it.
I was first using VDJ Home Free, which only supports external controllers for 10 minutes as a trial mode. Ugh.
I then tried VDJ LE Lite, the included version, which should work just fine, but it doesn't. I don't know why.
If I restart VDJ Home Free or uninstall/reinstall or whatever.. it does work for another 10 minutes. So the unit is fine, the software is being a bitch.
Another $49 for VDJ Pro? Sigh...
geposted Sun 11 Sep 11 @ 3:58 am
unfortunately you need the full version of pro not just basic... its $250 when upgrading from a 2go
geposted Sun 11 Sep 11 @ 5:56 am
I figured that, but why isn't LE Lite working?
geposted Sun 11 Sep 11 @ 7:41 am
Just get get VDJ Pro(Full)! Its worth it. Im sure everyone will agree with me=D
geposted Sun 11 Sep 11 @ 10:58 pm
^ aalaap...
you can order a numark mixtrack (not Pro )..
i just ordered one for $168 including shipping to india (not from eBay ). which also comes with vdj LE.
geposted Wed 09 Nov 11 @ 9:05 am
