I want to make a quick edit of the netbook skin to include a pannel that tells me if a certail shift is activated... i should be able to figure out how to include that, but is there a specific place in the xml that pannels are meant to be written in, or can it go anywhere?
Cheers
Andrew
Cheers
Andrew
geposted Thu 28 Jul 11 @ 11:07 pm
well if you want it in a pannel then there,but otherwise it can go anywhere.open various skins and you'll see.on some the browser xml on the top as opposed to the bottom on most....
geposted Thu 28 Jul 11 @ 11:24 pm
