its me or the nanopads mappings doesnt work with the neeww nanopad2 controlleR?? i wantt them!!!
i made my own basic mapper but iwant somenthing real cool from virtualdj.. something real great lol....
anyone has used the midifighter on virtualdj?
geposted Thu 28 Jul 11 @ 11:56 pm
It needs a definition file to work properly so the old nano one wont work, but you can just use simple midi with key learn
geposted Fri 29 Jul 11 @ 12:46 am
the definiition file is the one that is on the controller page then?
geposted Fri 29 Jul 11 @ 12:52 pm
im following the instructions on the nanopad+definition files , but it show me Failed to open the MIDI port???? what should i doo!!?? damn.... and it shows me the nanopad 1 not the 2 =S
geposted Fri 29 Jul 11 @ 1:07 pm
Can't give you advise, cause I gave up on mine a while back, but here is what you need to start https://virtualdj.com/addons/controllers.html?category=best&order=default&search=nanopad
Good Luck,
Joey...
Good Luck,
Joey...
geposted Fri 29 Jul 11 @ 1:09 pm
Well I don't have the 2nd version but I know for the first ones you have to go to the korg site and download the drivers and the korg editor program. My pad works perfect. I have it setup for the sampler. I load all the samplers with drum hits and when I feel a track needs some kicks or snares I just drum away.
Hope that helps
Huey
Hope that helps
Huey
geposted Fri 29 Jul 11 @ 3:30 pm
yeah the first edition works great.. but virtualdj look like doesnt support the 2nd =(
geposted Fri 29 Jul 11 @ 6:12 pm
Hi,
Please how can I map my nanopad2 with my Virtualdj LE for sampling and effects.
geposted Mon 04 Jun 12 @ 11:06 am
Your question is answered in the other topic where you asked the same question: https://virtualdj.com/forums/164844/General_Discussion/VirtualDJ_DIY_Controllers.html
Please don't ask the same questions in multiple threads.
geposted Mon 04 Jun 12 @ 2:45 pm
