Hi.I am tryin to use the 4 deck skin on the ns7 I can't get deck 3 and 4 to work. I can't figure out how to use the 4 deck on my ns7. Could someone help please.
geposted Sat 30 Jul 11 @ 6:16 am
Map this script to a button you don't use on your NS7,
device_side 'left' ? Deck 1 leftdeck ? deck 3 leftdeck & deck 3 select : deck 1 leftdeck & deck 1 select : deck 2 rightdeck ? deck 4 rightdeck & deck 4 select : deck 2 rightdeck & deck 2 select
Then use a four deck skin and you might have to go into the advanced sound config and route your decks out, not sure though cause I've never used one.
Let me know how it works out for ya.
Huey
Huey
geposted Sat 30 Jul 11 @ 7:33 am
I will do thank you.
Cheers
Cheers
geposted Sat 30 Jul 11 @ 7:49 am
hi i have tryed but it doesnt. any ideas?
geposted Sat 30 Jul 11 @ 2:14 pm
Doesnt what?? When you map a button on the NS7 does it effect both sides??
Huey
Huey
geposted Sat 30 Jul 11 @ 2:57 pm
I mapped it to the key lock all it does is changed the deck bit I cab play it?
geposted Sat 30 Jul 11 @ 3:27 pm
Ok map 1 side like this, Deck 1 leftdeck ? deck 3 leftdeck & deck 3 select : deck 1 leftdeck & deck 1 select
and the other with this, deck 2 rightdeck ? deck 4 rightdeck & deck 4 select : deck 2 rightdeck & deck 2 select
Like I said Ive never used one before, lol! Try that and let me know
Huey
Huey
geposted Sat 30 Jul 11 @ 3:47 pm
map 2 keys like this (you will control deck 3 with the deck' s 1 controls and vice versa) (same with the decks 2, 4)
deck 1 leftdeck ? deck 3 leftdeck : deck 1 leftdeck
deck 2 rightdeck ? deck 4 rightdeck : deck 2 rightdeck
now map every key like this (e.x. play/pause button)
for decks 1 and 3
leftdeck play_pause
for decks 2 and 4
rightdeck play_pause
for decks 1 and 3
leftdeck play_pause
for decks 2 and 4
geposted Sun 31 Jul 11 @ 1:35 pm
Well if he used the script I provided he wouldn't need to remap the keys cause it has the left, right logic aswell as deck 1/ deck 3 etc, etc...
Huey
Huey
geposted Sun 31 Jul 11 @ 1:41 pm
what key do I put your command in. I have tried alsorts and nothing is happening?
geposted Mon 01 Aug 11 @ 2:49 am
