Forum: Old versions
Topic: Mixtrack Pro & korg nanoPAD
Hi all, would like to know if there are any issues with running a mixtrack pro and a korg nano pad at the same time.
Would like to be able to use the nanopad for even more hot cues and to control effects and instajungle.
Havnt tried connecting them together to my computer but I thoughtthere migh be an issue as to which mapper VDJ will select and if you can have more then one midi controller connected at a time.
Regards Dj Klepht.
geposted Sat 30 Jul 11 @ 8:02 am
there is no problem with running multiple controllers, the best way to do it is to use mappers that have definition files, but if that's not possible you can use simple midi, but if you end up with more than just those two swap the next controllers onto a different channel, but I think I have read somewhere that the nanopad 1 is supported so is the mixtrack...
On another note can you let me know if you can get instajungle on more than one deck... I couldn't which sucks cause it's an awesome effect, but you can get everything accept the pitch shift with tex's loop roll
there is a bit of mapping for instajungle in this thread
https://virtualdj.com/forums/150880/PC_Version_Technical_Support/Script_Help_Please_______________.html
any ideas on how to map the xy pad on the NanoPAD2 as i want to assign those buttons you have for instajungle but i dont have any spare knobs on my mixtrack pro.
nah, have a read of the manual, it should tell you what the CC numbers are and if you can map em, had the same problem brought up by Huey the other day, but I have a feeling that the xy changes the repeat of the pads you are pressing, but if anyone is likely to have found an answer its him...
Just to let ya know i got instajungle running on both decks, just had to make sure i had selected the correct deck before doing it.
damn, I assigned to decks with script, so it must be compatabiliy with my computers, I made loop roll do the same thing though, just need to find a decent vst pitch shifter and it will have exactly the same function..
