Hey there, tonight me and my friend are doing our first gig, i am using a hercules rmx and my buddy is using a numark, both on our macbooks.
What cables do we need to switch off without killing the music? I was thinking an RCA Y Splitter, but i wasn't too sure and wanted to get advice on here. Sorry if this was a repeated topic question
Please help! Thanks!
geposted Sat 30 Jul 11 @ 12:42 pm
Never tried to run two LE versions at the same time, but maybe it is possible.
What numark controller do you use additional to the RMX?
Also with a LE version?
geposted Tue 02 Aug 11 @ 5:38 am
If you are going to be both playing off separate computers, then ideally you should use a standard hardware DJ mixer to allow to connect both computers simultaneously. If you are doing a gig at a bar of club, then they should already have a mixer installed as part of their sound system.
This will allow you to seamlessly switch, i.e: The master output of your RMX goes into channel 1 of the mixer and your friend's Numark master out goes into channel 2.
geposted Tue 02 Aug 11 @ 6:43 am
