iv been trying to setup timcodes with the hercules dj console mk2 and have a few problems...
the main one is when i press the audio source button it cuts the right side of the deck out???
here are a few picture of my settings and connections to see if that helps you with any advice...
thanks for any help :)
geposted Sun 31 Jul 11 @ 2:20 pm
geposted Mon 15 Aug 11 @ 6:08 pm
if you bought the unit used, be carefull tht its not a faulty unit.
geposted Wed 17 Aug 11 @ 6:58 am
