I now it may seam bad if I can not create a file in Macbook, but how to I get them created in VDJ
I thought the macbook would be simpler. I cannot make the files I had before on my PC. It is so easy
to to mix with what I know is there in my file. But stat over again....Wow?
I have; - MacBook Pro Quad core 2.3 i7 memory 4GB 750GB HD. Running a Full version VDJ Pro 7.
How do I get my FILES BACK.
geposted Sun 31 Jul 11 @ 8:34 pm
I got the files loaded into a folder but will not play in VDJ 7 pro, put into deck it read error. it will in VDJ 6 thought that is strange?
geposted Mon 01 Aug 11 @ 1:22 pm
What do you mean with "file creation"?
You have changed from PC to Mac?
You're music files are stored where and where was they stored on PC side?
How have you moved the files from PC to Mac?
geposted Tue 02 Aug 11 @ 5:30 am
