Topic: ok beginner here
ok the situation is i have all my connections pluged in for turntables to the virtual dj but when i go into config my imput button doesnt let me change anything to timecode but the timecode does read the asio as a soundcard. anyone know what im doing wrong so i can change my input? thanks you all
geposted Mon 01 Aug 11 @ 2:52 am
Can you give a little more details to what your setup is?
What version of VDJ?
What OS?
What is the controller your are using?
What is the soundcard you are using?
okay my setup is vdj basic on hp windows 7 sp1 already downloaded the drivers for connetiv interface as a sound card and torq timecode vinyls and a ion mixer..... im basically trying to connect turn tables..... when i go into my config under sound set up i cant change the input to timecode my output is on external mixer and my soundcard reads m-audio usb asio so it does read the connetiv just cant change the input.
i think you need VDJ Pro to use timecode
You will need the Pro Full edition of the software in order to use timecode and/or MIDI devices. It can be purchased and/or upgraded from your current product here: https://virtualdj.com/buy/
