can i use 2 mixtracks pro or 1 pro and 1 normal to use 4 decks on VDJ? on my mac?? i want to use 4 decks but i dont like to use the other 2 with my mouse selecting each deck to use it with mi mixtrackpro.. thanks!!
geposted Mon 01 Aug 11 @ 11:18 am
Yes this is possible, you'd just have go into the mappers tab in config and simply assign what decks go with what controller.
Hope this helps
Huey
Hope this helps
Huey
geposted Mon 01 Aug 11 @ 11:32 am
oh great, is just the tab that say ¨deck 1,2¨ and deck 3,4¨ or som like that or i would need to modify all the commands adding somenthig?
thanks for the info i just want to be shuure before i buy another one.. thanks!
geposted Mon 01 Aug 11 @ 11:47 am
there is an alternative
you can assign a button and toggle between decks 1/3 , 2/4 ......
with one controller on the 4 deck skin
geposted Mon 01 Aug 11 @ 12:21 pm
No need to modify the mapper or any commands (actions). You simply assign each controller to control either decks 1,2 or 3,4 through Mappers tab->Deck assignment.
geposted Mon 01 Aug 11 @ 12:46 pm
i was triying to do that on the mixtrack pro with the bmp buttons.. (the ones on each corner ) but i neverget it to work right
any advice on mapping that?
geposted Mon 01 Aug 11 @ 2:08 pm
oh great, and can i use the audio card on one mixtrack to hear 4 decks i guess i could be that way
geposted Mon 01 Aug 11 @ 2:09 pm
Button LEFT:
deck 1 select ? deck 3 select & deck 3 leftdeck : deck 1 select & deck 1 leftdeck.
Button RIGHT:
deck 2 select ? deck 4 select & deck 4 rightdeck : deck 2 select & deck 2 rightdeck.
So this mapping toggles between Deck 1 and Deck 3 each time you hit the LEFT button.
Same for Deck 2 and 4 with button RIGHT.
https://virtualdj.com/forums/136256/General_Discussion/Loyal_Pro_user_impressed_with_Version_7_features_-_Too_bad_Hercules_wasn_t_better_inform
this is for an rmx......adapt to suit
Button RIGHT:
geposted Mon 01 Aug 11 @ 2:29 pm
THANKS A LOOT i cant wait to get out of the work tooo try this out!! thanks a looot!
geposted Mon 01 Aug 11 @ 2:49 pm
