using mixtrack pro with vdj 7pro...mic works but when i record it doesnt come out ..what am i doing wrong...
geposted Tue 02 Aug 11 @ 9:19 am
Sorry, it is not possible to record the mic on the MixTrack Pro.
This is because the mic is hardware-based and routed directly to the output of its sound card. The audio signal from the mic is not sent to VirtualDJ, so it is not possible for it to record it.
geposted Tue 02 Aug 11 @ 9:39 am
ok thx so what is another way to record or do i just hook mic up to main amp n record thru audacity?
geposted Sun 23 Oct 11 @ 3:53 pm
i believe u set the mic as the input in advanced config, and that will work
geposted Sun 23 Oct 11 @ 5:34 pm
Advanced sound config is not possible in LE. Also, it would only work if using a mic from another sound card (E.g: Plugged into the mic input of the computer itself.) The MixTrack's mic is hardware and routed directly to the MixTrack's sound card.
If you are just using it at home, then you can simply plug the master output of the MixTrack into the line input of your computer and use 3rd party software such as Audacity to record. See https://virtualdj.com/wiki/Recording%20your%20set%20or%20broadcasting%20when%20using%20an%20external%20DJ%20mixer.html
If using it for live performance then you could use Y-cables to split the master output so it can be routed to both the line input for recording and your speakers.
geposted Mon 24 Oct 11 @ 5:14 am
LE? he said pro7 ....
at any rate it does require the adv config and send the mic output to any soundcard (could be the default system card)
geposted Mon 24 Oct 11 @ 2:48 pm
