just noticed that the latest version of vdj got rid of the line in option in the record/broadcasting section. any reason for this? i havent broadcasted in a while and wanted to do it today but it wasnt there. it was very helpful to me since i use and external mixer with no midi control
geposted Wed 03 Aug 11 @ 12:06 am
VDJ broadcast by default the master output signal to your station/listeners.
When you need to use a Mic or you mix with a external mixer, you have to do little bit more.
Connect your mixer/record or booth output with a "line in" port on your notebook or the used soundcard!
Go to VDJ Config - Soundcard and select Advanced Config.
Now you have to configure the setup, up to your needs and you have to use additional the action Record Loopback
You have to select the soundcard with the line in.
Now the VDJ Broadcast feature grab this input and route it to the stream.
https://virtualdj.com/images/pdf/VirtualDJ%207%20-%20Audio%20Setup%20Guide.pdf
geposted Wed 03 Aug 11 @ 5:18 am
