Is there a way to shut it off permanently?? Every time I open VDJ I have to go through and uncheck them, that's if I remember, otherwise ill be in the middle of a mix launch a sampler on one beat then crossfade over. Browse when I crossfade over and stop the other deck the sample pauses and resumes but off beat, Ughh! I bet this is something that'll have to be mapped to happen apon start-up?? So were all clear I'm talking about the samplers beatlock......
Thanks for the time and info
Huey
Huey
geposted Wed 03 Aug 11 @ 3:21 pm
So I assume I'm gonna just have to use the 'oninit' trick but whenever I make a new sample I'm gonna have to always go in and shut it off.
Guess you can't win them all.........
Thanks for time
Huey
Thanks for time
Huey
geposted Wed 03 Aug 11 @ 5:46 pm
Does this not work with the keyboard?? Or do I have to modifiy the skin?
Huey
Huey
geposted Wed 03 Aug 11 @ 6:05 pm
how about mapping this to your sampler play button... although if it works you will never be able to turn on beatlock unless you make another shift to override it
sampler # beatlock 1 ? sampler beatlock 0 & sampler # play : sampler # play
Untested... LOL
Untested... LOL
geposted Wed 03 Aug 11 @ 8:16 pm
The thing is the 'oninit' doesn't work for the keyboard but when I map it to my mixer it works fine.
Huey
Huey
geposted Wed 03 Aug 11 @ 8:32 pm
didn't even know there was an oninit option for a computer keyboard, I thought you meant a midi keyboard.. LOL
geposted Wed 03 Aug 11 @ 8:56 pm
Hahaa, maybe thats the problem, I couldnt find it so I just typed it in, lmao!!
Huey
Huey
geposted Wed 03 Aug 11 @ 8:59 pm
