Whats the script to map different beatgrid presets on a midi knob? or different buttons on a Hercules rmx?
geposted Wed 03 Aug 11 @ 5:10 pm
you can't actually map the buttons on beatgrid's gui, but another user had a great idea of renaming the dll file in the plugins folder and have different plugins with different patterns. then you just activate the specific beatgrid plugin
call the beatgrids
beatgrid_1.dll
beatgrid_2.dll
activate them with
deck # effect "beatgrid_1" active
deck # effect "beatgrid_2" active
call the beatgrids
beatgrid_1.dll
beatgrid_2.dll
activate them with
geposted Wed 03 Aug 11 @ 8:05 pm
so after programming a beatgrid close vdj then rename the dll file "_1" then open vdj and program the next and rename the default beatgrid.dll to beatgrid_2
geposted Wed 03 Aug 11 @ 8:48 pm
I would just name as many as you need first then program them second
geposted Wed 03 Aug 11 @ 9:08 pm
I took this technique a step further and hex-edited the copy of beatgrid.dll so it uses a different .ini file. That way it loads the custom beat grids automatically when VDJ loads up. :)
geposted Wed 21 Sep 11 @ 1:05 am
I don't exactly understand, but I like the way it sounds... can I get a copy?
cheers
cheers
geposted Wed 21 Sep 11 @ 3:38 am
Sure... here's the plugin: [link removed]
Put it in your plugins directory and it will be a completely different BeatGrid effect, and will save in it's own INI file (beatgri2.ini) so your presets can be different from the one in the original BeatGrid.
geposted Sat 24 Sep 11 @ 4:19 am
This does sound nice!! 1 question though, do I have to remove the original INI file?
Nice Work
Huey
Nice Work
Huey
geposted Sat 24 Sep 11 @ 4:42 am
It's worth noting that editing the files like that could be viewed as a breach of the licensing agreement. Sharing it like that is also a no-no.
geposted Sat 24 Sep 11 @ 12:55 pm
I would make the argument that as the beatgrid is a plugin and not part of the core virtual dj system itself, it is not subject to the license agreement.
Additionally, for someone who enhanced the functionality of a software to be reprimanded for it is a very poor customer service practice.
geposted Sat 24 Sep 11 @ 3:21 pm
can i have that link i missed it !!!
geposted Sat 01 Oct 11 @ 6:35 pm
