Hey gang..
Silly question you will probably think but i honestly don't know...is the vdj mac database cross compatible with the vdj pc version? A fellow dj has mac but we use pc at the club so i am wondering if her database would be able to be seen with our vdj pc version?
Thanks.
Thanks.
geposted Wed 03 Aug 11 @ 9:35 pm
JayMSY wrote :
Hey gang..
Thanks.
Thanks.
I'M not sure but my Mac picked up my folders from my pc external HD, without any problems.
geposted Thu 04 Aug 11 @ 5:21 am
The database on an external drive is cross-compatible, but it must be FAT32 format for Mac to be able to write to save changes to the database (Unless you have a 3rd party utility installed that allows writing to NTFS drives.)
If you wish to transfer the database for the internal drive to another computer (The one in My Documents\VirtualDJ on PC or /users/YOURNAME/Documents/VirtualDJ or /users/YOURNAME/Library/VirtualDJ on Mac), then you will need to manually edit the paths for all the files in the database, e.g: C:\Music -> /Music and PC style backslash \ with Mac style /. You must also have exactly the same folder structure and file names on both computers.
geposted Thu 04 Aug 11 @ 7:16 am
Just to make sure I understand...
if she does her database maintenance (analyzing, etc) on her MAC she can plug in the drive on the PC and all the information should be there as long as the drive letter is the same, correct?
geposted Thu 04 Aug 11 @ 10:46 pm
Yes, it's only the file path that requires to be changed. There are utilities that allow mac to pc drve access and vice versa.
Keith
Keith
geposted Thu 04 Aug 11 @ 11:01 pm
Jay,
With an external drive - the quote above is all you have to worry about. The drive must be a FAT32 formatted drive - only way both Mac and PC can each see the drive(s) and write to the drive(s). Everything else is plug-n-go.
Don't worry about all the internal drive stuff - that's not what you are asking. And, Don't worry about drive letter stuff. It will be fine.
Chris
geposted Thu 04 Aug 11 @ 11:26 pm
Sweet. Thanks so much. Btw Chris, hope you are doing well and staying cool.
geposted Sat 06 Aug 11 @ 12:04 am
i use a mac... when i plug my external hardrive with database into a pc i always get the file path /volumes/SEAGATE/music... my pc cant find the songs in a playlist bc it has /volumes in the beginning of the flile path.
any one konw how to get around this? or even know what i am talking about?? haha
geposted Sun 07 Aug 11 @ 5:29 am
