Sorry for the VERY noobish mapping question but I cant seem to get this right and ive been trying everything to get it working.
All I require is to be able to map the EQ to the keyboard.
Lets say I want to map Z key to reduce the level on the left deck eq_low and the X button to raise the eq_low. Potentially I would need 6 keys per deck to control them.
An even better option would be just to have 6 keys that would work both decks depending on what deck is selected if that is even possible?
All help is appriciated and im sure once I get my head around this im sure I can get to grips with it.
I used to mix about 7-8 years ago but got rid of all my kit once I had my daughter and now down the line I fancy getting a basic USB controller to have some fun with.
All the features that are missing really on the very cheap Numark USB2go is proper EQ controls. If I can get them mapped to the KB that would be fine for now. until I can get some serious kit.
geposted Mon 08 Aug 11 @ 3:46 am
you can do all of that...
to start, you can set it to work on the deck in pfl (pre fade listening) by using "deck default" when you are assigning the keys, next you need to set it to perform the action on something within vdj eg. eq_low, finally you need to set an amount that modifies the position of the thing you are changing eg "+1"
so when you put it together it will be
X) deck default eq_low +1
Z) deck default eq_low -1
but I made a eq undermix crossfader for a keyboard, but I'll see if I can modify it for a slider
here you go,,, Its a little lopsided because I needed one more position, but this still works, paste it into the crossfader
fake_crossfader & param_smaller 0% ? deck 2 eq_high 0% : param_smaller 2% ? deck 2 eq_high 5% : param_smaller 4% ? deck 2 eq_high 10% : param_smaller 6% ? deck 2 eq_high 25% : param_smaller 8% ? deck 2 eq_high 30% : param_smaller 10% ? deck 2 eq_mid 0% : param_smaller 12% ? deck 2 eq_mid 5% : param_smaller 14% ? deck 2 eq_mid 10% : param_smaller 16% ? deck 2 eq_mid 15% : param_smaller 18% ? deck 2 eq_mid 20% : param_smaller 20% ? deck 2 eq_mid 25% : param_smaller 22% ? deck 2 eq_mid 30% : param_smaller 24% ? deck 2 eq_mid 35% : param_smaller 26% ? deck 2 eq_mid 40% & deck 2 eq_high 40% : param_smaller 28% ? deck 2 eq_mid 45% & deck 2 eq_high 45% : param_smaller 30% ? deck 2 eq_mid 50% & deck 2 eq_high 50% : param_smaller 32% ? deck 2 eq_low 0% : param_smaller 34% ? deck 2 eq_low 10% : param_smaller 36% ? deck 2 eq_low 15% : param_smaller 38% ? deck 2 eq_low 20% : param_smaller 40% ? deck 2 eq_low 25% : param_smaller 42% ? deck 2 eq_low 30% : param_smaller 44% ? deck 2 eq_low 35% & deck 1 eq_low 50% : param_smaller 46% ? deck 2 eq_low 40% & deck 1 eq_low 45% : param_smaller 48% ? deck 2 eq_low 45% & deck 1 eq_low 40% : param_smaller 50% ? deck 2 eq_low 50% & deck 1 eq_low 35% : param_smaller 52% ? deck 1 eq_low 30% : param_smaller 54% ? deck 1 eq_low 25% : param_smaller 56% ? deck 1 eq_low 20% : param_smaller 58% ? deck 1 eq_low 15% : param_smaller 60% ? deck 1 eq_low 10% : param_smaller 62% ? deck 1 eq_low 5% : param_smaller 64% ? deck 1 eq_low 0% : param_smaller 66% ? deck 1 eq_mid 50% & deck 1 eq_high 50% : param_smaller 68% ? deck 1 eq_mid 45% & deck 1 eq_high 45% : param_smaller 70% ? deck 1 eq_mid 40% & deck 1 eq_high 40% : param_smaller 72% ? deck 1 eq_mid 35% : param_smaller 74% ? deck 1 eq_mid 30% : param_smaller 76% ? deck 1 eq_mid 25% : param_smaller 78% ? deck 1 eq_mid 20% : param_smaller 80% ? deck 1 eq_mid 15% : param_smaller 82% ? deck 1 eq_mid 10% : param_smaller 84% ? deck 1 eq_mid 5% : param_smaller 86% ? deck 1 eq_mid 0% & deck 1 eq_high 35% : param_smaller 88% ? deck 1 eq_high 30% : param_smaller 90% ? deck 1 eq_high 25% : param_smaller 92% ? deck 1 eq_high 20% : param_smaller 94% ? deck 1 eq_high 15% : param_smaller 96% ? deck 1 eq_high 10% : param_smaller 98% ? deck 1 eq_high 5% : param_smaller 100% ? deck 1 eq_high 0%
geposted Mon 08 Aug 11 @ 3:57 am
Thank you very much. :)
geposted Mon 08 Aug 11 @ 6:01 am
