I want to buy this DJ Controller http://www.hercules.com/it/DJ-Musica/bdd/p/110/dj-control-mp3-e2/
I want to know if I can do the following: Put the voice of ''S&M'' to sound[music(beat, bass, treble etc.)] of ''The Lazy Song'' for example. Is that possible to do on that DJ Controller?!
And also wanna know how to remove the voice from any song? :)
THANKS A LOT :)))
THANKS A LOT :)))
geposted Mon 08 Aug 11 @ 8:11 am
The controller will allow you to play both songs on top of each other, but you would need instrumental or accapella versions to get the perfect blend.
That is something better to be done in some sort of sequencing software, there are also some softwares available to extract vocals from a song but the results are a bit mixed.
Also bear in mind this is quite a low end controller and only comes with a older version of VDJ console edition.
Keith
Keith
geposted Mon 08 Aug 11 @ 8:25 am
re post...please only post questions once. this should be locked as the other one has more replies.
https://virtualdj.com/forums/151978/Mix_lessons/Tell_me_please__%29_.html
geposted Mon 08 Aug 11 @ 9:28 am
Double post -> https://virtualdj.com/forums/151978/Mix_lessons/Tell_me_please__%29_.html
LOCKED
geposted Mon 08 Aug 11 @ 9:30 am
