I got the mapper file before the upgrade came out the other day...FLAWLESS Totally awesome ...I am one happy camper...i can officially retire my VCI 100
its worth every penny!
my pc specs
acer extensa 5620
Processor / Speed Intel Core2 Duo mobile processor T7300/T7500/T7700 (4 MB L2 cache, 2/2.20/2.40 GHz, 800 MHz FSB) or
T7100 (2 MB L2 cache, 1.80 GHz, 800 MHz), supporting Intel 64 architecture
Core Logic Chipset Mobile Intel® GM965 Express Chipset
System Bus Speed 800 MHz FSB
RAM / Max RAM Up to 2 GB of DDR2 667 MHz memory, upgradeable to ((IM USING 2Gigs))
4 GB using two soDIMM modules (dual-channel support)
Video Subsystem Mobile Intel GM965 Express Chipset with integrated 3D graphics,
featuring Intel Graphics Media Accelerator (GMA) X3100 with up to 358/3845 MB of Intel Dynamic Video Memory Technology 4.0 (8 MB of dedicated system memory, up to 350/3765 MB of shared system memory), supporting Microsoft DirectX 9
LCD Properties 15.4\" WXGA high-brightness TFT LCD
1280 x 800 pixel resolution
Hard Disk Drive up to 160 GB Hard Disk Drive
Optical Drive 8X DVD-Super Multi double-layer or DVD/CD-RW Combo
(varies by model)
Battery, Primary
44.4 W 4000 mAh Lithium Ion 6-cell battery pack:
3-hour battery life
2.5-hour rapid charge system-off, 3.5-hour charge-in-use
Sound Subsystem Two built-in Acer 3DSonic stereo speakers
Intel High Definition Audio support
Built-in microphone, MS-Sound compatible
PCCard Support 1Type II PCCard slot
1 ExpressCard/54 slot
Pointing Device Touchpad
Peripheral Subsystem 4 USB 2.0 ports, 1 IEEE 1394 port (4-pin), 1 FIR port,
1 VGA port, 1 S-video/TV-out (NTSC/PAL) port
Headphones/speaker/line-out jack
Microphone jack/Line-in jack
5-in-1 card reader (SD, MMC, MS, MS PRO, xD)
Integrated Acer Crystal Eye webcam supporting enhanced Acer PrimaLite technology (varies by model)
Excellent work guys!!!!
my pc specs
acer extensa 5620
(varies by model)
Battery, Primary
3-hour battery life
geposted Mon 08 Aug 11 @ 10:38 pm
Dump the mapper that you downloaded and just use the built-in mapper for 7.0.5 it is the same.
** Don't do this if you have made modifications to your mapper - otherwise you will need to make them again.
geposted Tue 09 Aug 11 @ 12:00 am
