when i tough the jog wheel and the song pauses, when i let off there is a slight delay before the track starts playing again, is there a way to adjust this so that its immediate? most other programs have a setting for this or already start back up immediately.please help thank you!
geposted Mon 08 Aug 11 @ 11:11 pm
What MIDI controller are you using, if any?
Some MIDI controllers do not have touch-sensitive jogwheels. If this is the case for your controller, then there will need to upgrade to one that does. Please see https://virtualdj.com/wiki/Delay%20after%20scratching%20on%20controller%20that%20does%20not%20have%20touch-sensitive%20jogwheels.html
geposted Tue 09 Aug 11 @ 3:57 am
no. i have an M-audio Xponent it have perfectly fine jogwheels they worked fine on other programs, my friend has the numark mixtrack pro, and he has the same problem as well, is there a way to adjust this? latency issue?
geposted Sun 14 Aug 11 @ 4:28 pm
