Forum: Old versions
Topic: Opening the program
I downloaded my Virtual DJ and for a while it worked and now whenever i try to start the program it just comes up the skin you are trying to use does not fit with your screen so i click okay and the screen doesnt come up. It comes up on my desktop but the program doesnt come up, whats wrong with my Virtual DJ????
geposted Tue 09 Aug 11 @ 2:23 pm
Re-install the software again and it should revert back to the default size.
Make sure that you have the latest version from https://virtualdj.com/download/free.html
And make sure that your screen is set to at least 1024x768 resolution. Smaller screen sizes are not supported by default, but custom skins are available for Netbook users from https://virtualdj.com/addons/skins.html for registered licensed users. To download and use custom skins, you will need to purchase and register a VirtualDJ product: https://virtualdj.com/products/comparison.html
