@king mico, (shakes head in pitty)
geposted Mon 31 Oct 11 @ 2:10 pm
kradcliffe wrote :
VDJ 7 is 99.9% bug free.
How about letting us help with the problems before you go off on one?
This is likely to be a configuration issue with your current PC, just because it's new and powerful doesn't mean it is optimised for DJ use or free of bloatware.
As explained, if you had asked here on the forum, the advice would have been to go from VDJ5 to 6 to 7 then your database would have been converted properly and you wouldn't have had to scan all your files again. P.S. corrupted MP3's generally cause the scan to crash or stop so it's not a VDJ issue either.
Keith
Keith
@beatbreaker1 thanx and sorry and please read
@kradcliffe sorry please read
@blulite sorry please read
FIRST OFF, I'D LIKE TO APOLOGIZE TO ALL THE VDJ STAFF AND VDJ FANS I WAS ANGRY AND VERY BRATTY FOR MY LAST APPEARANCE.
FOR THIS I AM SO SO SO SORRY...
FOR ONE, I MUST SAY, VDJ HAS MOST DEFINITELY REVOLUTIONALIZED AND CHANGED THE FACE OF DEEJAYING (THE ART, THE CRAFT) FOREVER.
THE ISSUE I HAD WITH THE BPM DATABASE WAS SOLVED BY COPYING THE XML DATABASE FROM VDJ5 AND CHANGING THE NAME TO THE VDJ 6 DATABASE
AND KEEPING THE MUSIC DIRECTORY AND STRUCTURE THE SAME WAY IT WAS PRIOR TO THE REFORMAT THEN PLACING THOSE XML FILES IN THE SAME PLACES THEY WERE B4.
BUT I WOULD LIKE TO SAY MAYBE THE SCAN SHOULD SKIP AND LEAVE SOME INDICATOR TO HIGHLIGHT THE CORRUPTED FILES SO THE USER CAN REPLACE OR REMOVE
THEM FROM THE DATABASE AND THE SCAN CAN BE CARRIED OUT IF THE USER IS AWAY. (I MAY HAVE JUST MISSED IT THOUGH:\ )
I DIDNT HAVE VERSION 6 BECAUSE I WAS SCARED IT WOULDNT BE AS CONSISTENT AS VDJ5, BEING THAT IT TOOK ALOT OF TRIAL N ERROR
TO GET IT FINE TUNED WITH THE BCD2000 AND THEN THE HERCULES DJ CONTROL STEEL (SO MUCH BETTER THAN THE RMX IN CONTROLS, BTW).
FINALLY THE CROSSFADER CRAPPED ON THE DJ CONTROL STEEL AND HERCULES DISCONTINUED IT SO I HAD TO GET THE RMX (WHICH HAS NO FX KNOBS FOR TWEEKING >:[!!!!
SO THIS IS WHEN I STARTED USING 7. I FELT AS IF VDJ7 DIDNT LET ME CUSTOMIZE THE PERFORMANCE LIKE 5 DID AND THAT COUPLED WITH THE DISAPOINTMENT IN THE RMX
HAD ME PRETTY DOWN. SEEMED LIKE I HAD TO DO THE WHOLE TRIAL N ERROR THING ALL OVER AGAIN.
I BOUGHT THE NUMARK MIXTRACK FOR THE FX CONTROL KNOBS AND EXPERIENCED THE SCRATCHING PROBLEM.
BELIEVE IT OR NOT I FIXED IT ALL MYSELF AND I WAS CUTTING AWAY... AT THIS POINT, I HOPE U CAN SEE WHY A KID COULD GET SO FRUSTRATED.
I ALSO WANNA ADD, THAT I AM A PC TECH FOR MANY YEARS AND THE i7 QUAD CORE (8GB RAM NOW) 2000 NVIDIA CARD WAS BOUGHT - REFORMATTED - AND
WIN7 REINSTALLED WITH ONLY 5 TO 7 PROCESSESS RUNNING IN THE TASK MANAGER... WE HATES DA BLOATWARES!!! LOL
I DECIDED TO GET THE NUMARK MIXDECK AND I'VE HAD SOME IN CLUB CRASHES TILL I CAME UP WITH THE START UP FORMULA FOR IT AND VDJ 7...
- START THE MIXDECK
- PUT THE SOURCE TO MIDI ON EACH DECK
- THEN START VDJ7
- MIXDECK LCD SCREENS SHOULD INDICATE READINESS
- AND START MIXING
SINCE THEN NO CRASHES EXCEPT WHEN I PLUGGED IN A TERRABYTE USB HDD
I GUESS VDJ WAS READING IT AND BECAME UNRESPONSIVE... WONT DO THAT AGAIN. BUT ITS COOL.
I GUESS MY THING IS THAT I HAD TO REALIZE THAT VDJ (ALL U GUYS N GALS AT VDJ)
HAVE A VERY CHALLENGING JOB OF MAKING UR SOFTWARE TO WORK WITH A WIDE RANGE OF DEVICES NOT JUST THE ONES THAT I USE;)
BUT I WILL SAY THAT I THINK IN ORDER TO USE UR AWESOME NAME (VIRTUAL DJ) THE MANUFACTURERS OF THESE DIGITAL CONTROLLERS
NEED TO BUST A$$ A LIL HARDER TO MAKE SURE THEIR HARDWARE IS ----99.9% BUG FREE---- LIKE VDJ 7 IS.
I OWE YOU GUYS MY DIGI CONTROLLERS, MY STUDIO GEAR, MY SUPER HOT GIRLFRIENDS, MY COUNTLESS PAIRS OF POLO BOOTS, MY CADDILAC, MY AWESOME MIXES...ETC...
WHAT IM TRYIN TO SAY IS,,, ALL OF U CHANGED MY LIFE DRAMATICALLY... INCLUDING MY WALLETS LIFE... THANK U AND SORRY AGAIN...
DJ KING MICO
!!!!!!!!WE DONT USE NO SYNC BUTTON 'ROUND HERE, BUDDY!!!!!!!
FIGHTING SERATO AND TRAKTOR USERS WITH BLOODY KNUCKLES...
whats wrong with the way i spell "sux"
geposted Tue 08 May 12 @ 10:24 pm
please check my reply to kradcliffe
geposted Tue 08 May 12 @ 10:26 pm
@keith
is ther a tool for corrupted mps 3 on here?
geposted Thu 10 May 12 @ 2:52 am
No, there is no tool that has anything to do with VDJ, although I guess there would be 3rd party tools available.
You tend to find corrupted MP3s are ones obtained illegaly. Files that have been ripped on your own PC or bought from legitimate sources normally don't have any problems.
Keith
Keith
geposted Thu 10 May 12 @ 6:56 am
