Forum: Old versions
Topic: Shoutcast server loses connection?
I set Virtual DJ Pro Basic to stream on the internet through a Shoutcast server.
I've set up VDJ to be allowed through my firewall, I've opened the ports on my router, I've put my PC in the router's DMZ, and I've used QOS to give the ports high priority.
The shoutcast server streams at 256 kbps. I set Virtual DJ to that.
The servers are located in Dallas, Texas. So I did a speedtest check for Dallas, so see what my upstream is. I get 3 Mbps.
After about 20 minutes of streaming, the stream goes dead. Shoutcast server says no source connected. I look at VDJ, and it's still happily playing, and the recording tab has no error messages. If I stop recording and click it again, it reconnects and I can start with no issue. But this is not good, being cut off every 20 minutes.
I've tried another shoutcast server, and I've had the same issue.
geposted Thu 11 Aug 11 @ 12:51 am
Update: DPC Latency Checker hovers around 100, with very rare spikes as high as 870.
same issue and just started its not my net or router or modem and i have pro vdj 7 but cant find info to update here so it kinda sucks
Please contact support to retrieve your Pro serial number:
https://virtualdj.com/contact/
Then register it on the page https://virtualdj.com/users/edit.html to be able to download the latest and future versions of VirtualDJ from the Download Center: https://virtualdj.com/download/updates.html
Also, check your computer for performance issues: https://virtualdj.com/wiki/Performance%20Issues.html
And make sure that you have the latest drivers and firmware installed for the Denon MC6000 - These can be obtained from http://www.denondj.com
thanks for your help .... really helped me out : ) big ups
