Does any know of how to add the effects downloaded from here into the actual VDJ software?
geposted Fri 12 Aug 11 @ 10:17 am
Sorry, the software that you received with your MixTrack is a limited edition and does not allow custom skins, effects, etc. to be used or the program configuration options to be changed (Except during the 20 day trial of Pro.) Please see https://virtualdj.com/products/comparison.html
To be able to use custom skins, effects and much, much more you will need to upgrade to the full VirtualDJ Professional. Your VirtualDJ LE entitles you to a discount off the cost of upgrading. To receive this, please go to https://virtualdj.com/buy/ and enter your software serial number in the box provided at the bottom of the page (The MixTrack Pro will give you the most discount.)
Before upgrading, you can also try out Pro features in VirtualDJ v7 Home FREE by going to https://virtualdj.com/download/free.html - This software will allow you to test your MIDI controller with it for 10 minutes at a time before reverting back to internal mouse and keyboard control only.
geposted Fri 12 Aug 11 @ 10:23 am
