Hello, I just started to manually map my Mixvibes U-Mix Control 2 controller, but I seem to have a problem when mapping the knobs.
For instance, I mapped a knob to browse to the effects using 'deck 1 effect select +1', but when i turn it the menu always selects the second next effect, making it more like +2 instead of +1.
Anyone have any ideas how can I fix this?
On a related note, I'd also like to know whether it is possible to map the LED's when a button is pressed, such as the knob eq kill, I can't seem to make it work no matter what commands I use. Thanks for the support.
geposted Fri 12 Aug 11 @ 10:20 am
I'm not sure why it would be working at all. I don't think that the no-license version has MIDI control features.
If you upgrade to pro, there is full MIDI support, as well as native support for MANY controllers.
geposted Fri 12 Aug 11 @ 12:53 pm
