Hey guys. Im still fairly new to Virtual DJ and giving it a good try though before I purchases the full version.
Just a quick Script/Mapping question. How do I get a hot-key on the keyboard to load the next song in my play list to what ever deck (Eg The 'A' key loads the next song in the playlist onto Deck A and the 'B' key loads the next song in the playlist onto Deck B)
Thanks in advance.
Thanks in advance.
geposted Sun 14 Aug 11 @ 5:41 am
hi, you only need to map one button.
map and key and set its action to: load
this will load the next track on your playlist into which ever deck is empty or stopped.
hope this helps.
oh and if your wondering, why controllers have a load A and load B button, its because "load" is a global action and run off the same commmand.
you can map 2 keys if you please and you will still get the exact same thing.
map A to = load
map B to = load
but why use two when one will do?
hope this helps.
map A to = load
map B to = load
geposted Sun 14 Aug 11 @ 6:25 am
Thanks for your reply.
The only probelm Ive been finding with that is I have to press down and have the song highlighted that I want to load. So therefore pressing down then 'load'. I would like to combine the two to make it heaps easier.
Thanks
EDIT: I think I know where Im going wrong. Is it better do it from a Folder because thats what I have my 'set' in right now.
Thanks
geposted Sun 14 Aug 11 @ 6:36 am
that should work on any highlighted track. not just tracks in a playlist.
any track tou hghlithg in a browser it should load to.
lemme double check though
ok i see where your coming from, map your buttons to this
A = deck 1 load
B = deck 2 load
this gives specific seperation so you can load any highlighted track to the specific deck.
hope this helps.
A = deck 1 load
B = deck 2 load
hope this helps.
geposted Sun 14 Aug 11 @ 7:23 am
Thanks for the help. I kinda got what I want going.
Cheers.
Cheers.
geposted Mon 15 Aug 11 @ 6:13 am
ok cool ,glad i could help.
geposted Tue 16 Aug 11 @ 6:41 pm
