Topic: Hercules Rmx With Denon DN-SC2000
Need help here guys. I already have the rmx and love it. However, I would like to be able to scratch a bit so was thinking about adding one Denon DN-SC2000. How do I hook up and configure for best results?
geposted Sun 14 Aug 11 @ 9:32 pm
Please explain why you can't use the RMX to scratch?
What makes you want to use the Denon instead?
The Rmx jogs are not touch sensitive so there is too much lag on release.
Ok - was just wondering - I have never used the RMX
You would need to upgrade to the full VirtualDJ Professional at a considerable discount to use the DN-SC2000 or any other MIDI controllers alongside the RMX: https://virtualdj.com/buy/
With the full Pro, you can use multiple MIDI controllers at the same time. On the SC2000, there is a DECK button to switch between controlling the left and right decks.
Another option is to simply upgrade to an all-in-one controller that has touch sensitive jogwheels such as the new Hercules 4-Mx or 4Set or the Numark MixTrack Pro.
