I cant record because when i go to the record thing and i click on the thing when u can change the name of it and stuff,the first box is blank and i dont knw what to type in so it saves! D: (Im a bit of a computer noob btw)
geposted Mon 15 Aug 11 @ 4:58 pm
You need a License
geposted Mon 15 Aug 11 @ 5:13 pm
I need a lisence to record mixes ive made?!?!
geposted Mon 15 Aug 11 @ 5:15 pm
Use the Home version, then find the plugin lame_enc.ddl on the folder.
C:\\\\Users\\\\Administrador\\\\Documents\\\\VirtualDJ\\\\Plugins\\\\lame_enc.dll
and ready, r you decide there if to do it in a single file or several..
Regards
geposted Mon 15 Aug 11 @ 5:25 pm
It worked!Thank you so much!!!
geposted Tue 16 Aug 11 @ 4:32 am
