If you got a Dell which I also have, that is always the case, if you download drivers from the component vendor, then you will have issues..
Always update drivers from the computer maker first, unless yours is a custom built unit..., always check first to save headaches later..
geposted Fri 07 Oct 11 @ 10:14 am
cheers joey mate.will always do this from now on for every driver i need.just more testing from now till i go back to work...too much time to think now ha.
is it just download codec pack and vdj will auto find them or do i need to add the pack to vdj someway.
and i reverted back to 7.0.4 as on my gig laptop as have no problems not sure if 7.5b has a problem or not but just reverted back
geposted Mon 10 Oct 11 @ 7:12 am
The install of Codec will be triggered by the file type it is assign, which mean you don't need to put it into a particular folder and it will be used automatically if needed.....that's it...no fuss..
Good Luck,
Joey...
Good Luck,
Joey...
geposted Mon 10 Oct 11 @ 1:16 pm
i have game booster on my pc as well advance system care, quick care and malware fighter.
should i put this on my lappy as well and lappy has smart ram
geposted Tue 11 Oct 11 @ 2:48 am
the game booster that is
geposted Tue 11 Oct 11 @ 2:49 am
pseft mate...as you probably read im doing what the lads are telling me to help me.
i use the gamebooster 3 now but only on this laptop so not sure of your specs or if you need it.
maybe lads will chime in
geposted Tue 11 Oct 11 @ 4:26 am
i installed this last week on my PC coz i got a game for my nephew and hes been busting my balls to buy him a lappy for his gaming... hes only 11 years old, so i said id uprade my pc and he can use that.
geposted Tue 11 Oct 11 @ 4:31 am
what i do notice is when i activate gamebooster it says it freed up memory and brought cpu down so i have to believe its doing something good ha.
geposted Tue 11 Oct 11 @ 4:43 am
Would turning off the the powermixer on the video card also help the freezing/stuttering I am seeing when scrolling over the waveforms?
geposted Tue 11 Oct 11 @ 11:57 am
Yes, if it has it, Kill it....Make sure is Dead.....
geposted Tue 11 Oct 11 @ 6:44 pm
Yes, My experience has been good with these so far...
Good Luck,
Joey....
geposted Tue 11 Oct 11 @ 6:46 pm
