Got a budget of 100-120ish, and essentially want something similar to this for use with VDJ but with an inbuilt sound card for the headphone pre-listening and such. Can anyone help recommend something? (UK Based)
geposted Thu 18 Aug 11 @ 5:06 pm
I'd say that is the bare minimum, but your probably better off saving a little more and getting a reloop mixage, It will be better build quality than the herc, and a little bigger with touch sensitive jogs. 191 pounds @ junorecords not sure if they come with vdj though... If not you would need pro to use it which would cost more
geposted Fri 19 Aug 11 @ 4:42 am
