can any one tell me how to hook up the rmx to the numark ndx 800 its driving me insane I cant figure it out i reset my mapping got the rca out of the ndx to the in put of the rmx 1&2 and so as i press source 1 their is a wave form that continues to move thru the wave form bar on vdj? someone help would be much appreciated.
thanks
thanks
geposted Fri 19 Aug 11 @ 12:22 am
Nevermd I figured it out!!..not just have mapp it out now.
geposted Fri 19 Aug 11 @ 4:11 am
The NDX-800 is a MIDI controller and natively supported. It doesn't need mapping (Unless you wish to change the default to your own preferences.)
Simply plug each NDX-800 and your computer using a USB cable, then put it into PC/MIDI mode.
Make sure that you have the latest version of VirtualDJ installed: https://virtualdj.com/download/updates.html
geposted Fri 19 Aug 11 @ 5:01 am
Thats what I ended up doing. My other question is that I'm using a Mac book which unfortunately only has two USB drives, now do I use the two from the MAC for the RMX and NDX800 or do I need to get a POWERED HUB to use for the controllers and the other one off the Mac for the HHD or plug the HHD into the usb port on the NDX800? Right now I using a cheapie 4 hub non powered from wally world. which hasn't been under any real stress of gigging and is doing fine with no lag yet. I know one had mention earlier that the NDX800 is mapped for VDJ already which is good but I would like to remap the RMX to other functions that is not mapped. Or DID YOU MEAN THAT THEIR MAPPED ALREADY TO WORK TOGETHER?
geposted Sat 20 Aug 11 @ 2:05 am
You should plug the hard disk directly into a USB port of the Mac itself because this will use the most USB bandwidth (Bandwidth on a hub is shared between all connected devices.)
Plug the NDX-800's and RMX into a powered USB hub. The RMX is a USB bus-powered device, so may not get enough power if plugged into a non-powered hub. NDX-800's have their own power supply, so this shouldn't be an issue. Alternatively, use the optional external power supply for the RMX.
The RMX and NDX-800's are natively mapped in VirtualDJ to perform appropriate functions for each button. If you wish to customise them to perform different functions, please see https://virtualdj.com/homepage/jpboggis/blogs/4149/VDJscript_Mapping.html
geposted Sat 20 Aug 11 @ 1:05 pm
